Eee Pad Transformer Prime TF201 LED Chip Replacement
Выберете то, что вам нужно
  1. Eee Pad Transformer Prime TF201 LED Chip Replacement, Opening Your Device: шаг 1, изображение 1 из 1
    • Power down your device.
    • Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
  2. Eee Pad Transformer Prime TF201 LED Chip Replacement: шаг 2, изображение 1 из 3 Eee Pad Transformer Prime TF201 LED Chip Replacement: шаг 2, изображение 2 из 3 Eee Pad Transformer Prime TF201 LED Chip Replacement: шаг 2, изображение 3 из 3
    • Insert the plastic opening tool into the seam near the corner of the device.
    • Slowly slide the tool around the perimeter of the device, gradually prying up the screen.
    • It is normal to hear snaps as the spring clips holding the screen in place are released.
    • It is also normal to hear adhesive separating, as a small amount is used to help secure the screen.
  3. Eee Pad Transformer Prime TF201 LED Chip Replacement: шаг 3, изображение 1 из 3 Eee Pad Transformer Prime TF201 LED Chip Replacement: шаг 3, изображение 2 из 3 Eee Pad Transformer Prime TF201 LED Chip Replacement: шаг 3, изображение 3 из 3
    • When the screen is free of all spring clips and adhesive, slowly open the device like a clam shell with the hinge being the left hand side of the device.
    • Do not completely separate the screen from the case by more than a few inches, as they are still connected by three orange ribbon cables.
    • Safely place the device back on the table by laying the screen face down.
    • There will be some slight overlapping of the back of the case over the screen.
  4. Eee Pad Transformer Prime TF201 LED Chip Replacement: шаг 4, изображение 1 из 2 Eee Pad Transformer Prime TF201 LED Chip Replacement: шаг 4, изображение 2 из 2
    • Disconnect the ribbon cable by placing a plastic opening tool under the black plastic tab that is on the opposite side of the port as the ribbon cable.
    • Pry upward until the black tab moves 90 degrees, and gently pull the ribbon cable out of the port.
  5. Eee Pad Transformer Prime TF201 LED Chip Replacement: шаг 5, изображение 1 из 1
    • Place a plastic opening tool under the white plastic tab on one of the ribbon cable ports.
    • Repeat the previous process to remove the other ribbon cable.
  6. Eee Pad Transformer Prime TF201 LED Chip Replacement: шаг 6, изображение 1 из 1
    • Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
    • The device that we wrote this guide for did not come with a battery, so we cannot include it in our own guide steps.
    • The battery is removed during all repairs to protect against short circuits, shocks, and internal damage to the device.
  7. Eee Pad Transformer Prime TF201 LED Chip Replacement, LED Chip: шаг 7, изображение 1 из 2 Eee Pad Transformer Prime TF201 LED Chip Replacement, LED Chip: шаг 7, изображение 2 из 2
    • With a Phillips #00 screwdriver, remove the one 3.8 mm screw in the LED chip. The LED chip is a small green chip (about 1 square centimeter) located at the top center of the device.
    • Gently remove the chip with a pair of precision tweezers by grabbing the chip from one side, being careful not to pinch on a black piece of hardware on the chip.
Заключение
Aaron Morland
Участник с: 10/06/16
346 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 10-1, Livingston Fall 2016 Участник Cal Poly, Team 10-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G1
2 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 271
