Выберете то, что вам нужно
Place the controller face down (buttons and joystick down).
Use a Phillips Head #1 screwdriver to remove the eight 9.65mm screws located on the felt and metal backplate.
Open the door for the cord storage compartment on the right side of the device.
Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
Individually remove the seven cable connectors plugged into the logic board by grasping each white plug and gently pulling upwards.
Use a Phillips Head #1 screwdriver to remove the two 7.15mm washer head screws from logic board.
