Введение
Use this guide to replace the batteries on a Drive Electric Wheelchair.
Locate the two batteries under the back of the wheelchair.
Pull the first battery pack to where you can reach the red battery connector.
One at a time, disconnect the clips holding each battery case closed.
Open each case to reveal the battery inside.
Remove the old battery from each case.
Put one new battery into each plastic case the old batteries were removed from.
Place the first battery back into the holder under the wheelchair.
Place the second battery back into the holder.
Reconnect the black battery connectors.
Reconnect the red battery connectors.
Check that the chair turns on and is fully charged.
3 участников успешно повторили данное руководство.
Один комментарий
I greatly enjoyed reading your article :) Please continue publishing helpful topics like this. Regards, from <a href="http://www.scootersnchairs.com">Scooters 'N Chairs</a>.
