Введение
The life of the battery will reduce and it won't work after a certain amount of time using the device. Therefore, it is always good to check the battery first before taking it apart.
This guide is to inform the reader how to remove and replace battery in an electrohome EAAC475 safely when a battery problem occurs.
Выберете то, что вам нужно
Remove the 10 mm Phillips #1 screw from the battery cover.
Remove the battery cover.
2 участников успешно повторили данное руководство.
