Выберете то, что вам нужно
Remove 6 screws.
12.5mm self tapping screws with 2.0mm hex socket head
Use a small flat-headed screwdriver, spudger, or similar to pry open the lid enough to be able to get a grip of it and pull straight back and then fold down.
Remove the limit switch cable connector in the bottom right corner by pulling it straight out.
Remove the two screws securing the limit switch.
M4x7.5mm socket screw with 2.5mm hex socket head
Hold the limit switch in the lower end and pull it downwards.
Еще один человек закончил это руководство.
2 Комментариев
I've looked everywhere and can't seem to find a place to buy a replacement limit switch. Any suggestions?
I got my replacement directly from Elegoo support. Send them an email, they are very helpful.
