Введение
Use this guide to access the headphone jack and check soldered connections. If you are planning to follow this replacement guide, you should have identified the headphone jack as a source of a problem (or maybe you just want to see the guts of your Element GC-1020).
Выберете то, что вам нужно
Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
Carefully pull the back of the device (the silver portion) apart from the rest of the device.
Еще один человек закончил это руководство.
