Выберете то, что вам нужно
Pull up from the bottom its held on by some clips and adhesive. All you need are your hands
Slowly pull up until the entire front cover is off
Pry up on the bottom
Pull out the module be careful to not pull on the cable to hard
Bend the tabs on either side of the metal housing out.
I recommend using pliers to do this
Be carefulk not to break the ribbon cables under the board.
Remove the yellow tape to access the ribbon cable connectors
The connector on the left and middle you pull up on the black piece to remove the cable
The connector on the right you pull the black connector away from the white part (it should look like the picture)
Bend all the latches out of the way.
The 4 on the sides (2 on opposite sides) bend outwards like the ones before
The 2 on top bend upwards.
Push up on the buttons to get the screen module up until you can pull it out.
DO NOT pull on the cables as you risk damaging them
Carefully peal up on the black film.
The 2 smaller ribbon cables are attached to the black film
