Введение
If your Ematic Model FTABMP2 has a cracked or damaged screen, refer to this guide to learn how to replace it. The screen on this device is a Full 4.3 LCD Screen Display with Touch Screen Digitizer Glass Panel.
Make sure your device is powered off before you begin.
Выберете то, что вам нужно
Gently insert the blue spudger in between the two sections of the tablet and go around breaking the glue seal.
Gently take off the back side of the tablet.
Locate the light grey clamp on the motherboard and gently use two index fingers to disconnect the black LCD cable from the motherboard.
Gently press on the white clamp using the blue spudger to remove the metal panel.
