Введение
This is a replacement guide for the exhaust fan for the Epson PowerLite 822 Plus. Model number EMP-822H. When the exhaust fan is not working as it should that is when the projector could overheat and cause it to not work. This guide will show you how to remove and replace the current exhaust fan in your projector.
Выберете то, что вам нужно
Flip the projector over.
Remove all 8 screws on the bottom of the projector.
Now, flip the projector back over and pry the top of it open revealing the inside of the projector.
Using your finger gently move back and forth the JST cable that connects the top to the motherboard.
Now completely take off the top of the projector.
Now, the motherboard is completely removed from the projector and you are ready to replace it.
Gently lift the fan bracket up and remove it and it is ready to be replaced.
