Epson Stylus NX230 Front Button Replacement
Выберете то, что вам нужно
  1. Epson Stylus NX230 Front Button Replacement, Front Buttons: шаг 1, изображение 1 из 1
    • Before beginning, make sure the printer is unplugged and turned off to avoid electric shock.
    • Lift the top of the printer to see the inside.
  2. Epson Stylus NX230 Front Button Replacement: шаг 2, изображение 1 из 3 Epson Stylus NX230 Front Button Replacement: шаг 2, изображение 2 из 3 Epson Stylus NX230 Front Button Replacement: шаг 2, изображение 3 из 3
    • Locate the control panel, the part of the printer with the buttons on it.
    • Push the control panel away from the outside of the printer, taking the panel out of the holes that hold it in place.
    • Repeat the above step for the other side of the control panel.
  3. Epson Stylus NX230 Front Button Replacement: шаг 3, изображение 1 из 2 Epson Stylus NX230 Front Button Replacement: шаг 3, изображение 2 из 2
    • The front control panel is attached to the printer on both sides by a grey piece of plastic that runs on a track. Remove the control panel from the track by pushing it away from the track on both sides.
    • The ribbon cable on the left side of the control panel, also known as the ribbon cable, must stay attached to the printer. If the cable becomes detached the front buttons will not be responsive.
  4. Epson Stylus NX230 Front Button Replacement: шаг 4, изображение 1 из 1
    • Flip the detached control panel over so that the buttons are facing down.
    • Remove the two 3mm Phillips #2 screws from the back of the control panel.
  5. Epson Stylus NX230 Front Button Replacement: шаг 5, изображение 1 из 1
    • Lift up the gray plastic piece.
    • Remove the 3mm Phillips #2 screw.
  6. Epson Stylus NX230 Front Button Replacement: шаг 6, изображение 1 из 1
    • Split the control panel in half by gently pulling on both sides of the seam that runs through the control panel.
  7. Epson Stylus NX230 Front Button Replacement: шаг 7, изображение 1 из 2 Epson Stylus NX230 Front Button Replacement: шаг 7, изображение 2 из 2
    • Separate the two pieces to reveal the green circuit board.
    • Be sure to not detach the circuit board from the white tap.
    • Remove the green circuit board by lifting it up gently with your hands.
  8. Epson Stylus NX230 Front Button Replacement: шаг 8, изображение 1 из 1
    • Remove the buttons with the plastic opening tool by pressing the front panel down and lifting the buttons up.
Заключение
To reassemble your device, follow these instructions in the reverse order.
2 участников успешно повторили данное руководство.
Danielle Purdy
Участник с: 04/07/14
309 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 6-1, Forte Spring 2014 Участник Cal Poly, Team 6-1, Forte Spring 2014
CPSU-FORTE-S14S6G1
4 членов
Автор 10 руководств
Один комментарий
Wow! this guide is clear and concise. wahoo!!!
kyle price - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 12
За всё время: 835
