Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Locate the control panel, the part of the printer with the buttons on it.
Push the control panel away from the outside of the printer, taking the panel out of the holes that hold it in place.
Repeat the above step for the other side of the control panel.
The front control panel is attached to the printer on both sides by a grey piece of plastic that runs on a track. Remove the control panel from the track by pushing it away from the track on both sides.
Flip the detached control panel over so that the buttons are facing down.
Remove the two 3mm Phillips #2 screws from the back of the control panel.
Lift up the gray plastic piece.
Remove the 3mm Phillips #2 screw.
Split the control panel in half by gently pulling on both sides of the seam that runs through the control panel.
Separate the two pieces to reveal the green circuit board.
Remove the green circuit board by lifting it up gently with your hands.
Remove the buttons with the plastic opening tool by pressing the front panel down and lifting the buttons up.
2 участников успешно повторили данное руководство.
