Epson Stylus NX305 Scanner Motor Replacement
Выберете то, что вам нужно
  1. Epson Stylus NX305 Scanner Motor Replacement, Scanner Motor: шаг 1, изображение 1 из 1
    • Make sure that the printer is not plugged in before working on it.
    • Orient the printer so that the back of it is facing you.
  2. Epson Stylus NX305 Scanner Motor Replacement: шаг 2, изображение 1 из 1
    • Locate the 3mm Phillips #0 screw that is on the right-hand side of the printer.
    • Using a Phillips head screwdriver, remove the screw.
  3. Epson Stylus NX305 Scanner Motor Replacement: шаг 3, изображение 1 из 2 Epson Stylus NX305 Scanner Motor Replacement: шаг 3, изображение 2 из 2
    • Open up the lid of the printer.
    • With the printer facing away from you, lift up on the right hand side of the lid of the printer and slide it to the left to remove it.
    • Be careful not to remove the white ribbon and wires that are connected.
  4. Epson Stylus NX305 Scanner Motor Replacement: шаг 4, изображение 1 из 1
    • With the printer facing you, open the lid of the scanner to expose the 3mm Phillips #0 screw at the top left of the scanner.
  5. Epson Stylus NX305 Scanner Motor Replacement: шаг 5, изображение 1 из 1
    • Locate the six 3mm Phillips #2 screws under the lid of the printer and remove them.
  6. Epson Stylus NX305 Scanner Motor Replacement: шаг 6, изображение 1 из 1
    • Locate the three clips on the front side of the printer lid.
    • Use the plastic opening tool to release the clips and carefully pry open the lid.
  7. Epson Stylus NX305 Scanner Motor Replacement: шаг 7, изображение 1 из 1
    • Locate the belt that is attached to the scanner motor and remove it by carefully stretching off of the gear.
  8. Epson Stylus NX305 Scanner Motor Replacement: шаг 8, изображение 1 из 1
    • Remove the two 3mm Phillips #2 screws from the scanner motor assembly.
    • Carefully lift the scanner motor assembly out of the housing making sure not to damage the wiring.
  9. Epson Stylus NX305 Scanner Motor Replacement: шаг 9, изображение 1 из 1
    • Flip over the scanner motor assembly to expose the scanner motor.
    • Remove the two 3mm Phillips #2 screws from the assembly and remove the motor.
Заключение
Jeffrey Barnett
Участник с: 09/21/14
101 Репутация
1 руководство автора
Команда
USF Tampa, Team 1-2, Donnelly Fall 2014 Участник USF Tampa, Team 1-2, Donnelly Fall 2014
USFT-DONNELLY-F14S1G2
1 член
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 466
