Введение
To get to the inside parts of the printer, the housing components must come off.
Выберете то, что вам нужно
Turn off the printer.
Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
Locate the IEEE cover in the back.
Gently slide the cover to the right to unlatch, then pull to remove it.
Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
Remove the 6 mm screw that holds the rear housing in place.
Insert a plastic opening tool into the cutouts of the lower housing.
Release the two tabs of the side housing by lifting the tool in an upward motion.
Remove the side housing by pulling it outwards.
Remove the four 10 mm Phillips #2 screws from the sides of the printer.
Remove the three 6 mm Phillips #2 screws.
9 участников успешно повторили данное руководство.
Один комментарий
Thank you so much, Larry! I am repurposing my 1400 for sublimation printing and need to get the print head a little easier than standard methods! Much appreciated!
