Epson Stylus Photo 1400 Ink cartridge replacement
Выберете то, что вам нужно
  1. Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: шаг 1, изображение 1 из 2 Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: шаг 1, изображение 2 из 2
    • Open cover of the printer.
    • Open the cartridge cover by pressing down on the tab and lifting it up.
  2. Epson Stylus Photo 1400 Ink cartridge replacement: шаг 2, изображение 1 из 2 Epson Stylus Photo 1400 Ink cartridge replacement: шаг 2, изображение 2 из 2
    • Grab the sides of the ink cartridge and pull it out.
    • Replace ink cartridge with brand new ink cartridge.
  3. Epson Stylus Photo 1400 Ink cartridge replacement: шаг 3, изображение 1 из 2 Epson Stylus Photo 1400 Ink cartridge replacement: шаг 3, изображение 2 из 2
    • Close cartridge cover.
    • Close cover of the printer.
Заключение
Еще один человек закончил это руководство.
Larry Huang
Участник с: 10/12/11
953 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 17-11, Regan Fall 2011 Участник Cal Poly, Team 17-11, Regan Fall 2011
CPSU-REGAN-F11S17G11
4 членов
Автор 12 руководств
5 Комментариев
I cannot change the ink cartridges because when I press the Ink button they will not stop in a position where I can open the container. Nothing I've tried works -- can you help please? URGENT!!!
David Hardy - Ответить
I actually found this quite easy because of your guide. There was no issue at all with replacing the ink cartridge in my printer and now I can print again! Is there anything else I need to worry about after I put the cartridge in? http://tonertown.com.au
chrishowell562 - Ответить
You missed the part where you tell people how to get the cartridge to a position where you can open it. Mine is block because it is over to the side too far.
Paul M - Ответить
Poor instructions on how to get ink cartridge holder in right position.
rpttrsn - Ответить
Instruction intimates the ink carriage will be in position when parked. Not so…with it parked in the extreme right, you cannot get the ink cover open. jdw
joe waldroff - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 33
За всё время: 9,693
