Epson TM-U300 Cutter Blade Replacement
Выберете то, что вам нужно
  1. Epson TM-U300 Cutter Blade Replacement, Remove the cutter unit: шаг 1, изображение 1 из 3 Epson TM-U300 Cutter Blade Replacement, Remove the cutter unit: шаг 1, изображение 2 из 3 Epson TM-U300 Cutter Blade Replacement, Remove the cutter unit: шаг 1, изображение 3 из 3
    • Make sure the power supply/interface cables are disconnected before proceeding!
    • Open the print head/ribbon cartridge cover.
    • Remove the two Phillips screws securing the two grounding brackets which hold the cutter unit in place.
    • Set the metal brackets aside.
    • Do not pull on them forcibly – you risk tearing the grounding wires.
    • Remove the cutter, being careful not to tear/pinch the cable coming from it.
    • Disconnect the cable connecting the cutter to the printer.
  2. Epson TM-U300 Cutter Blade Replacement, Disassemble the cutter: шаг 2, изображение 1 из 3 Epson TM-U300 Cutter Blade Replacement, Disassemble the cutter: шаг 2, изображение 2 из 3 Epson TM-U300 Cutter Blade Replacement, Disassemble the cutter: шаг 2, изображение 3 из 3
    • Caution: The screws are quite soft and easy to strip.
    • Make sure the cutter assembly is oriented so that the motor/gears face you.
    • Remove the three screws holding the two halves in place.
    • Separate the two halves, making sure not to damage the wires.
  3. Epson TM-U300 Cutter Blade Replacement, Remove the blade: шаг 3, изображение 1 из 3 Epson TM-U300 Cutter Blade Replacement, Remove the blade: шаг 3, изображение 2 из 3 Epson TM-U300 Cutter Blade Replacement, Remove the blade: шаг 3, изображение 3 из 3
    • The blade will be accessible after separating the two halves.
    • The blade is sharp! Be careful not to injure yourself.
    • Make sure to note the position the blade is installed in.
    • The toothed edge should be facing the opening for the paper, with the longer of the three notches on the right (assuming the frame is oriented as pictured).
    • Make sure to route the wires coming from the cutter assembly through the groove in the left hinge of the print head cover when reinstalling the assembly into the printer.
Заключение
To reassemble your printer, follow these instructions in reverse order.
Fifo F
Участник с: 03/12/15
148 Репутация
1 руководство автора
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 250
