Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Запчасти
Детали не указаны.
  1. Insert the flat end of a spudger on both sides of the wiring box to open and detach the box from the clock. Insert the flat end of a spudger on both sides of the wiring box to open and detach the box from the clock. Insert the flat end of a spudger on both sides of the wiring box to open and detach the box from the clock.
    • Insert the flat end of a spudger on both sides of the wiring box to open and detach the box from the clock.
  2. remove the box with your fingers.
    • remove the box with your fingers.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Detach the wires that connect the wiring to the battery compartment and the copper cylinder by using soldering iron. Detach the wires that connect the wiring to the battery compartment and the copper cylinder by using soldering iron.
    • Detach the wires that connect the wiring to the battery compartment and the copper cylinder by using soldering iron.
  5. Using your hand remove the wiring box and replace it with a new one. Using your hand remove the wiring box and replace it with a new one.
    • Using your hand remove the wiring box and replace it with a new one.
Заключение
Еще один человек закончил это руководство.
Alaa
Участник с: 27.10.2014
228 Репутация
Автор 2 руководств
Команда
Eastern Washington University, Team 1-6, Carnegie Fall 2014 Участник Eastern Washington University, Team 1-6, Carnegie Fall 2014
EWU-CARNEGIE-F14S1G6
6 членов
Автор 6 руководств
Один комментарий
Is there someone I can send my alarm clock to for fixing? IF so, how much would it cost? I do not have the tools nor the know how to do it. Most likely, the alarm will have to be replaced. The little motor on the inside is not working when it is time for it to go off. It does not move the ringer/clanger. Thanks,
mariacarbonell@comcast.net
Maria Carbonell - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 23
За всё время: 1,946
