Введение
We have about 25 of these soldering stations in my workplace, but after 5 or 6 years of use, their display backlight started to fail. Without backlight, the display is almost illegible. Since 4 stations have developed this problem so far, I've decided to investigate.
At the time Ersa didn’t offer standalone replacement displays; they forced you to buy a new control board costing a whopping 160 EUR, which is almost half the price of a new soldering station. Nowadays it is possible to buy replacement displays under the catalog number 3EBLCD128x64 for 33 EUR, though at the time the only option I could find was this American e-shop, but shipping costs to Europe start around 100 USD. That's better, but still not exactly cost-effective (50 USD displays, 100 USD shipping). The displays are probably manufactured somewhere in China, but I couldn't identify their original manufacturer, nor I was able to find another source (Ebay, Alibaba...) for them. If someone finds them, please let me know in the comments. Here are markings that are on the back of the display:
PRE-WU2495B-01
ED-5455-LED/A ROHS
0712FJB*1094/0107/1*6
Anyway, since I couldn't get new displays for reasonable price, I decided to replace burned backlight LEDs in the displays. I used LTW-108DCG-HS10 as replacement LEDs in this guide, but any miniature white LEDs with at least 1000 mcd luminous intensity should do. See step 14 for more information.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Spudger$3.99
Pull off the control knob using a nylon spudger.
Use pliers or a wrench to unscrew the four plastic nuts holding the display in place.
The display backlight is hidden under white tape on the right side of the display.
Carefully remove the white cover tape using a knife or similar tool.
Use a knife or similar tool to hold down the circuit strip and unstick it from the cover tape.
Use a knife or similar tool to carefully unstick the circuit strip from the plexiglass base.
The strip is held in place with a thin, transparent, double-sided tape. Be sure to keep the tape on the plexiglass base as you remove the strip. If the tape tears away with the strip, use the tip of the knife to push it back onto the plexiglass.
Fold the circuit strip onto the back cover of the display and weigh it down. This will expose the faulty original LEDs and some resistors.
After analyzing the original backlight connections, it became clear why it fails: the Chinese designers who created the display wanted to save space and money by connecting the LEDs in parallel.
However, since each LED has a slightly different threshold voltage, one of them draws more current and fails prematurely. The remaining two LEDs then experience even higher currents and burn out soon afterwards.
To address this issue, I decided to change the connection according to the lower schematic. I shorted the original 22R resistors and put a 220R resistor in series with each new LED.
There is enough room on the strip to solder in new LEDs (red arrows) along with their 220R resistors (green arrows) on the original solder pads.
Desolder the original 22R resistors and short their pads with a thin wire.
Stick the circuit strip back onto the plexiglass base.
Secure the strip in place with a new tape cover, such as brown electrical tape.
Reassemble the soldering station carefully and test the display to confirm that it's working properly.
Here you can see comparison of original (left) and new backlight (center). The new backlight is slightly brighter than the original; you can use larger resistors (270 or 330R instead of 220R) to lower the brightness.
I also experimented with general-purpose VLMW11R2S2-5K8L-08 omidirectional LEDs. You can see the result on the station on the right - the display is rather dim and there is significant backlight bleed on its right edge, where the LEDs are located. Thus I recommend to use only directional, right-angle LEDs like LTW-108DCG-HS10.
Since new LEDs need lower current to achieve similar light output, they should outlast the soldering station. This "trick" is generally applicable; high-brightness LEDs always generate more light at 2 mA than ordinary LEDs at 20 mA. At the same time, they consume less power, generate less heat and last much longer.
6 участников успешно повторили данное руководство.
7 Комментариев
Thanks a ton. We have ~20 units in our facility and experiencing the same issue. I feel like writing a preventive action to ERSA. I've followed your steps, bought the LEDs and found some 120ohm (0603) resistors laying around. You are pretty accurate on the time. It's about 20mins after you get the first couple done. The results are night and day (pun intended...lol). I do like the irons and they work great, but just one drawback is the display design. Huge cost savings to do them yourself, but you need to have a light hand, and don't burn anything. I used 3 layer paper under the circuit, exacto blade and tweezers to peel the tape back. The recommended LED part number (LTW-108xxx) works great. Thanks for this awesome money saver, our employees are happy they can see the display again. You Rock!
Thank you for your detailled walktrough.
I have found two types of screen on my ersa icon1. Lucky me one of the screens had a sticker with the model identification and is equal to your screen. =)
The model is ES13BB0BMW, manufactured by EMERGING DISPLAY TECHNOLOGIES CORP.
The only place I could find it for sale was here:
https://www.questcomp.com/part/4/ES13BB0...
But i am still waiting for a quote, because unfortunly my screen is dead.
You can also find a link to the datasheet on the above link.
I attemped connecting the other screen, the different one, and found it to no work properly on the pcb. The text gets faint. Dont know why yet.
Hello Again,
I have just found the other display version. Is quite easy to find on the web.
AMG12864PR-G-B12WTDW
http://www.orientlcd.com/mobile/Product....
On the above link you can also find the datasheets.
It also looks like someone already figured it out befor me.
https://www.eevblog.com/forum/repair/rep...
However altough thee pcb is the same, there are some differences on the mounted components. A direct compatibility can not be possible.. Maybe even software is different.. I will walk through the displays datasheets and see what might be needed to ensure compatibility between the two versions.
If I can pull it out I will maybe do a walkthrough in this.
The LCD controller is the same on both LCDs .. SITRONIX7565P , meaning that software should be compatible.
The display from Orient is confirmed to work just by direct replacement. =)
