Введение
If the Passport Max2's lens gets cracked or damaged, this guide will communicate how to replace it.
Выберете то, что вам нужно
Inser the flat end of a spudger into one of the two notches and pry off the case.
Slide the spudger around the perimeter of the radar housing until the case separates.
Remove the four 9mm Phillips #1 screws from the bottom of the radar.
Remove the bottom case.
Gently spread apart the thin silver frame that wraps around the device and remove the dark purple lens.
