Введение
This guide will show you how to replace the battery connector. This replacement is necessary if a new battery is installed and the device still won't work or if the wires break. This will use a screwdriver and a soldering iron. Be careful when using the soldering iron as it is very hot. There is a link to a soldering guide in the Troubleshooting section of the device page.
Выберете то, что вам нужно
Pull the battery cover away from the handle by gripping near the thumb groove.
Disconnect the battery by pulling the connector away from it.
Positive first
Negative second
Realign the buttons with the button terminals.
Red terminal to red button.
Orange terminal to orange button.
Yellow terminal to yellow button.
Use a soldering iron and melt the solder where the battery connector's wires are attached to the motherboard.
