Введение
This guide will show you how to repair a trigger that has a faulty connection. If the trigger will depress and not return to its original position or if it will not even depress, this will be necessary. The tool needed is a screwdriver. There are no hazards in this guide.
Выберете то, что вам нужно
Pull the battery cover away from the handle by gripping near the thumb groove.
Disconnect the battery by pulling the connector away from it.
Positive first
Negative second
Realign the buttons with the button terminals.
Red terminal to red button.
Orange terminal to orange button.
Yellow terminal to yellow button.
