Введение
Prerequisite only.
Выберете то, что вам нужно
Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
Use the T10 hexagonal tip from the iFixit Bit Driver Kit or comparable tool to remove the two 22 mm hexagonal screws on the front face of the device.
Use a long, slender screwdriver to reach and remove the two 10 mm Phillips #00 screws recessed deep in the body of the device.
On the bottom of the device are two rubber feet. Using the blue plastic opening tool, pry them up and pull straight off.
Pull apart the two halves of the device at the seam.
Three components from the back half will prevent you from fully opening the device, just unplug these connections as shown in the image.
Еще один человек закончил это руководство.
