Eton FRX3 Dynamo Unit Replacement
Выберете то, что вам нужно
  1. Eton FRX3 Dynamo Unit Replacement, Rechargeable Battery Pack: шаг 1, изображение 1 из 1
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 Dynamo Unit Replacement: шаг 2, изображение 1 из 1
    • Disconnect the battery pack wires from the device and remove the battery pack.
  3. Eton FRX3 Dynamo Unit Replacement, Case Assembly: шаг 3, изображение 1 из 1
    • On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
  4. Eton FRX3 Dynamo Unit Replacement: шаг 4, изображение 1 из 1
    • While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
  5. Eton FRX3 Dynamo Unit Replacement: шаг 5, изображение 1 из 1
    • Remove the two Phillips #00 screws located in the center of the back of the device.
    • You will need to use a thin shafted screwdriver or a female hexagonal bit that is found in the iFixit 54 bit toolkit to extend the reach of the Phillips #00 bit.
  6. Eton FRX3 Dynamo Unit Replacement: шаг 6, изображение 1 из 1
    • On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
    • Try to keep the adhesive on the rubber feet as clean as possible to insure that they can be reattached during reassembly.
  7. Eton FRX3 Dynamo Unit Replacement: шаг 7, изображение 1 из 1
    • Pull the two halves of the device's case apart.
    • Take care when pulling the two halves apart. There are three cables that connect components of the device to the motherboard. Disconnect these cables in order to separate the two halves of the device's case.
  8. Eton FRX3 Dynamo Unit Replacement, Tuning Dial: шаг 8, изображение 1 из 1
    • Unplug the socket connection from the motherboard as shown in the image.
  9. Eton FRX3 Dynamo Unit Replacement: шаг 9, изображение 1 из 1
    • Remove the two 1 cm Phillips #0 screws that secure the tuning dial panel to the motherboard.
  10. Eton FRX3 Dynamo Unit Replacement: шаг 10, изображение 1 из 1
    • Gently lift the dial upwards to remove it.
  11. Eton FRX3 Dynamo Unit Replacement, Motherboard: шаг 11, изображение 1 из 1
    • Remove the six Phillips #0, 1 cm screws that secure the motherboard to the case.
  12. Eton FRX3 Dynamo Unit Replacement: шаг 12, изображение 1 из 1
    • Unplug all the component socket connections from the motherboard.
  13. Eton FRX3 Dynamo Unit Replacement: шаг 13, изображение 1 из 1
    • Desolder the two wires that connect the speaker to the motherboard.
  14. Eton FRX3 Dynamo Unit Replacement: шаг 14, изображение 1 из 1
    • Gently lift the motherboard upwards to remove it from the device.
  15. Eton FRX3 Dynamo Unit Replacement, Dynamo Unit: шаг 15, изображение 1 из 1
    • Remove the four Philips #00 screws securing the dynamo to the case.
  16. Eton FRX3 Dynamo Unit Replacement: шаг 16, изображение 1 из 1
    • Gently pull the dynamo straight upwards to remove it.
    • The gears and where they are seated on the dynamo, are covered in grease. Try to avoid touching where the gears seat, to keep the new gears as lubricated as possible!
Заключение
To reassemble your device, follow these instructions in the reverse order.
Еще один человек закончил это руководство.
Kenneth Sills
Участник с: 02/10/16
762 Репутация
Автор 6 руководств
Команда
USF Tampa, Team 1-6, Nance Spring 2016 Участник USF Tampa, Team 1-6, Nance Spring 2016
USFT-NANCE-S16S1G6
4 членов
Автор 13 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 773
