Eton FRX3 FM Radio Antenna Replacement
Выберете то, что вам нужно
  1. Eton FRX3 FM Radio Antenna Replacement, Rechargeable Battery Pack: шаг 1, изображение 1 из 1
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 FM Radio Antenna Replacement: шаг 2, изображение 1 из 1
    • Disconnect the battery pack wires from the device and remove the battery pack.
  3. Eton FRX3 FM Radio Antenna Replacement, Case Assembly: шаг 3, изображение 1 из 1
    • On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
  4. Eton FRX3 FM Radio Antenna Replacement: шаг 4, изображение 1 из 1
    • While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
  5. Eton FRX3 FM Radio Antenna Replacement: шаг 5, изображение 1 из 1
    • Remove the two Phillips #00 screws located in the center of the back of the device.
    • You will need to use a thin shafted screwdriver or a female hexagonal bit that is found in the iFixit 54 bit toolkit to extend the reach of the Phillips #00 bit.
  6. Eton FRX3 FM Radio Antenna Replacement: шаг 6, изображение 1 из 1
    • On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
    • Try to keep the adhesive on the rubber feet as clean as possible to insure that they can be reattached during reassembly.
  7. Eton FRX3 FM Radio Antenna Replacement: шаг 7, изображение 1 из 1
    • Pull the two halves of the device's case apart.
    • Take care when pulling the two halves apart. There are three cables that connect components of the device to the motherboard. Disconnect these cables in order to separate the two halves of the device's case.
  8. Eton FRX3 FM Radio Antenna Replacement, FM Radio Antenna: шаг 8, изображение 1 из 1
    • Remove the Philips #1 screw, securing the FM radio antenna to the case.
  9. Eton FRX3 FM Radio Antenna Replacement: шаг 9, изображение 1 из 1
    • From the back of the device, gently pull the antenna out of the device case.
Заключение
To reassemble your device, follow these instructions in the reverse order.
Еще один человек закончил это руководство.
Md Siamul Islam
Участник с: 02/10/16
423 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 1-6, Nance Spring 2016 Участник USF Tampa, Team 1-6, Nance Spring 2016
USFT-NANCE-S16S1G6
4 членов
Автор 13 руководств
3 Комментариев
I bought 2 of these overpriced made in China crap and antenna broke off easily on both. Truly disappointed . Want to replace them with better heavy duty antenna. What brand and model and company do you recommend U buy the antennas from?
Olga Limkin - Ответить
where can I get the antenna?
Claude Raasch - Ответить
This helps when you leave it within reach of a 5 yr old who swears he did it when "he was little"
Joseph - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 12
За последние 30 дней: 17
За всё время: 2,010
