Eton FRX3 Rechargeable Battery Pack Replacement
  1. Eton FRX3 Rechargeable Battery Pack Replacement, Rechargeable Battery Pack: шаг 1, изображение 1 из 1
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 Rechargeable Battery Pack Replacement: шаг 2, изображение 1 из 1
    • Disconnect the battery pack wires from the device and remove the battery pack.
Заключение
To reassemble your device, follow these instructions in the reverse order.
3 участников успешно повторили данное руководство.
Kenneth Sills
Участник с: 02/10/16
762 Репутация
Автор 6 руководств
Команда
USF Tampa, Team 1-6, Nance Spring 2016 Участник USF Tampa, Team 1-6, Nance Spring 2016
USFT-NANCE-S16S1G6
4 членов
Автор 13 руководств
4 Комментариев
My question is where can you find an FRX3 replacement battery?
jalwitt - Ответить
Hey mate, you can buy the battery packs from a number of sources. Here's the link to one of those sources https://www.amazon.com/HQRP-FR200-BAT-3A...
james -
is it ok to replace it with a higher capacity lithium battery?
troydeleon - Ответить
As long as the specifications match, that should be fine. Just be careful when swapping out components in circuits, as it can potentially destroy the device if they're incompatible!
Kenneth Sills -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 33
За всё время: 5,289
