Eureka 1660SP External Start Switch Realignment
Выберете то, что вам нужно
  1. Eureka 1660SP External Start Switch Realignment, Motor Housing: шаг 1, изображение 1 из 2 Eureka 1660SP External Start Switch Realignment, Motor Housing: шаг 1, изображение 2 из 2
    • Before you start, make sure your vacuum is unplugged the power outlet.
    • Press and hold down the black button below the handle while pulling the pole out.
  2. Eureka 1660SP External Start Switch Realignment: шаг 2, изображение 1 из 2 Eureka 1660SP External Start Switch Realignment: шаг 2, изображение 2 из 2
    • Press the black separator switch to separate the top and bottom halves of the vacuum.
  3. Eureka 1660SP External Start Switch Realignment: шаг 3, изображение 1 из 3 Eureka 1660SP External Start Switch Realignment: шаг 3, изображение 2 из 3 Eureka 1660SP External Start Switch Realignment: шаг 3, изображение 3 из 3
    • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
    • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
    • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
  4. Eureka 1660SP External Start Switch Realignment, Realignment of plastic start switch piece: шаг 4, изображение 1 из 3 Eureka 1660SP External Start Switch Realignment, Realignment of plastic start switch piece: шаг 4, изображение 2 из 3 Eureka 1660SP External Start Switch Realignment, Realignment of plastic start switch piece: шаг 4, изображение 3 из 3
    • If the external switch is slightly misaligned as shown, realign it with the internal switch.
    • Make sure the spring loaded button on the underside of the housing is intact when reassembling the motor housing. It is prone to eject when opening the motor housing.
Заключение
Evan Fodi
Участник с: 09/24/13
122 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 Участник UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G1
3 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 11
За последние 30 дней: 13
За всё время: 2,457
