Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Запчасти
Детали не указаны.
  1. Before you start, make sure your vacuum is unplugged the power outlet. Press and hold down the black button below the handle while pulling the pole out.
    • Before you start, make sure your vacuum is unplugged the power outlet.
    • Press and hold down the black button below the handle while pulling the pole out.
  2. Press the black separator switch to separate the top and bottom halves of the vacuum. Press the black separator switch to separate the top and bottom halves of the vacuum.
    • Press the black separator switch to separate the top and bottom halves of the vacuum.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown. Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing. Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
    • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
    • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
    • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
  5. Pull out the button and the spring attached to it.
    • Pull out the button and the spring attached to it.
    • Swap the old spring with a new one.
  6. Insert the new spring and button back into the right slot as shown in the picture.
    • Insert the new spring and button back into the right slot as shown in the picture.
Заключение
Nikhila Vijaybhaskar
Участник с: 24.09.2013
224 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 Участник UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G1
3 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 202
