Введение
Replace the small wheel or 'roller' on the bottom of the Eureka.
Выберете то, что вам нужно
Press the black separator switch and lightly pull the bottom half away from the top.
Turn the vacuum head wheels up and remove all seven 13.9mm screws from the bottom using a #2 Phillips head screwdriver.
Separate the top and bottom of the vacuum head. Set the top aside.
Turn the vacuum head's bottom over so that the inside of the head is facing up.
Using a Phillips #00 screwdriver, press down on metal bar of the roller on one side until it releases from the housing.
Turn the vacuum head's bottom over and pull at the roller and bar until they are completely out of the housing.
