Введение
Some vital parts of the vacuum cleaner require you to remove the casing in order to replace them. This guide serves as a prerequisite only to the guides on how to replace those parts.
Выберете то, что вам нужно
Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
Unscrew the 14mm PH2 Phillips head screw.
Pull the bottom cover off of the rest of the casing.
Unscrew the six 18.1mm PH2 Phillips head screws on the side of the vacuum.
Pull the casing apart.
Еще один человек закончил это руководство.
