Введение
Does the remote control to your FAO Schwarz have a dead or corroded battery? This guide will show you how to replace your remote control battery in just four easy steps, with no additional tools needed. Your remote control should be working in no time!
Выберете то, что вам нужно
Remove the plastic battery cover to get at the battery compartment.
The cover can be removed by pressing down on the lever and sliding.
Remove the dead battery, being careful not to damage the internal battery connectors.
The battery is a bit wedged in there, so you'll have to press hard to pop it out.
Insert the new 6F22 9 volt battery.
Line up the positive icons on the battery with the positive icons in the battery compartment.
