Выберете то, что вам нужно
Remove 6 Screws from Base of Printer
Carefully remove cover.
Using small needle nose pliers gently remove the plastic clip that holds the stepper cable connector.
Rotate the plastic clip 180º
Gently, but firmly, press the plastic clip back onto the board.
Align the pins in the correct location and position.
Press gently but firmly into place.
Remove sticker from back of heat sink
Carefully press the heat sink to the back of the TMC2208
Remove Old Driver
Reverse Direction of Stepper
Insert TMC2208
Add Heatsink
Plug Stepper Back In
Re-assemble your printer and enjoy near silent (fans make some noise) printing!
2 участников успешно повторили данное руководство.
8 Комментариев
I haven't needed to mess with it.
You can either, flip the orientation of the plug on the board, or modify config values in the firmware config file and re-flash the firmware. I chose to flip the plug so I would need to mess with flashing firmware.
Do you need to reverse the plug for a 2209? Difference between 2208 and 2209 for my QQS Pro?
