Factory Reset, Fix Android Problems with Sony PC Companion
Видео обзор
  1. Factory Reset, Fix Android Problems  with Sony PC Companion, Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 1, изображение 1 из 3 Factory Reset, Fix Android Problems  with Sony PC Companion, Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 1, изображение 2 из 3 Factory Reset, Fix Android Problems  with Sony PC Companion, Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 1, изображение 3 из 3
  2. Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 2, изображение 1 из 2 Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 2, изображение 2 из 2
    • Install Sony PC Companion in your PC.
  3. Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 3, изображение 1 из 3 Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 3, изображение 2 из 3 Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 3, изображение 3 из 3
    • Connect your laptop to power supply since the update of your phone will take some time.
    • Now choose "repair my phone / tablet". By this way you can fully erase your phone and remove any security password, PIN etc., or change firmware if your phone have OS problem and can't be powered on correctly.
    • This is your last warning about losing your personal data.
    It will not let me does this because I haven’t got the password for my phone so when I go onto the pc companion it says that because my phone is locked I can’t do it I just need to be able to unlock my Xperia M2 help!!
    Taya louise - Ответить
  4. Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 4, изображение 1 из 2 Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 4, изображение 2 из 2
    • PC Companion will download some files to prepare your PC for software update.
    • Your phone / tablet must be at last 80% for the update to proceed safely!
  5. Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 5, изображение 1 из 3 Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 5, изображение 2 из 3 Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 5, изображение 3 из 3
    • Select the model of your phone.
    • You should not confuse the model.
  6. Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 6, изображение 1 из 3 Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 6, изображение 2 из 3 Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 6, изображение 3 из 3
    • The USB cable must be connected only to the PC.
    • Turn off the phone.
    • Press and hold the Volume Down button while plugging the cable into your phone.
    • Once connected, PC Companion will download necessary firmware and will upload it to your phone.
  7. Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 7, изображение 1 из 3 Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 7, изображение 2 из 3 Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 7, изображение 3 из 3
    • Your PC must recognize your phone like SOMC Flash Device.
    • If you have a problem with drivers (your PC can't recognize your phone), search in the internet for "S1Boot Fastboot" drivers or use the link below.
    • '''Android WinUSB drivers'''
  8. Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 8, изображение 1 из 3 Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 8, изображение 2 из 3 Factory Reset, Fix Android Problems  with Sony PC Companion: шаг 8, изображение 3 из 3
    • When PC Companion finished with update process, disconnect the phone and switch it on.
    • Now your phone is in factory condition, with erased custom data and without password protection.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
    After repair software does not success and may the device contains modified software that cannot be repaired error code Ue getphoneinforooteddevice UE-2003
    rabindrashrestha98 - Ответить
Заключение
113 участников успешно повторили данное руководство.
ZFix
Участник с: 12/09/13
191 308 Репутация
Автор 330 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 535 руководств
26 Комментариев
thanks so much. btw if it says you should unlock first, just press emergency calls and it accepts it
Godstime Osarobo - Ответить
my xperia ( LT22i ) is not listed
abdul azeem - Ответить
there is an error every time i try to use pc companion
error code: uegetphoneinfofailure
leo leo - Ответить
there are an error
I can't download the upgrade on my phone
arnold - Ответить
can any one help me ??????????
arnold - Ответить
handset is stuck in a boot up mode / optimising of application - screen and power on/off have no effect - keeps repeating this process and getting hotter?
since the new android marshmellow tried to download - ???
PC Companion does not acknowledge the connection to the handset - requests to wait until restart complete and/or PCC detects handset - neither happen as stuck in loop - cables are all ok
HELP
Xperia Z
Kevin - Ответить
I can't get the three options that come after clicking on the "Support Zone " option, I need help!!!!
thom4jesus - Ответить
If you use Windows 10 you need to disable the driver signature enforcement to install the android usb drivers from the Sony homepage. For that you need to do an restart with special setup of Windows 10.
Claes - Ответить
Sony Xperia Z C0682 is not in the model list. What should I do?
Warren Razon - Ответить
how long does it takes (hrs) on software repair?? any guys.. ^^', tnx alot
karr pasaporte - Ответить
I can't download the PC Companion!!!!!!!!!!!!!!!!
honeylight18 - Ответить
I'm having issues with my battery suddenly dropping to 0 while using the phone even when not using the phone it dies after about 3hrs. Can I do a factory reset or could my battery die during the process?
I Also did a battery health test and it said the battery is good
Clive Donk - Ответить
What to do if the program says you have to unlock the phone, but you dont remember the passcode...?
Thomas Bakke - Ответить
same man, what you do?
totouron24 -
How to recover my sony xperia d2005 after installing software update disconnected? I can open my phone but only dead android can see.
rafael jr matulac Jaen - Ответить
mon téléphone portable Sony refuse de s'allume je ne sais pas si il est programme ou pas . je ve que vous m'aider. model D2005.
jean - Ответить
Hi.
My Xperia e3 dual device is under continue boot loop. Can it be rectified by master format.. Also is there any possibility for data recovery if I don't have a back up done
vipul - Ответить
I'm having issues with my battery suddenly dropping to 0 while using the phone even when not using the phone it dies after about 1hrs. Can I do a factory reset or could my battery die during the process?
Sujith Nettur - Ответить
I'm having issues with my Xperia z1 battery suddenly dropping to 0 while using the phone even when not using the phone it dies after about 1hrs. Can I do a factory reset or could my battery die during the process?
The current version of Xperia Companion (v. 1.5.3.0) had 2 errors on my PC (W7 64 SP1):
1) Setup with .DLL problem: I fixed the problem by installing an update for Windows - Windows KB 2533623 (Windows6.1-KB2533623-x64.msu) -, easily found on the Microsot website. After the update, the Companion was installed normally;
2) Several failures when trying to upgrade or repair my smartphone, such as "unexpected error", "login failure", "download failure", etc .: I corrected the problem by uninstalling the "Sony Mobile Update Engine", by Control panel. This software is installed automatically by the Xperia Companion setup. After uninstalling this software, Xperia Companion will no longer display any errors (and will install the Sony Mobile Update Engine again during the operation of your device, this time not causing the error!).
At least for me everything worked this way and, since I did not see this unusual solution on another site, I decided to post it, in case it would be useful to someone else.
Good luck!
donizildodasilva - Ответить
please whats the file to format my xperia its too slow and keep reloading over and over again
ayola robinson - Ответить
dear sir/ madam,
on my system, the Sony pc companion is not installing please help me.
Arwinder Singh Mann - Ответить
hi how are u sir my phone xperia vl is not open password and no reset how can i solve it plz tell me soultion
syed adnan - Ответить
Amazing this is so help full thank you so much SP flash
decorationideas3 - Ответить
??? if i have Malware on my phone can using this program infect my lap top
Tanya Kintz - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 8
За последние 7 дней: 39
За последние 30 дней: 164
За всё время: 231,402
