Введение
Restore functionality to your Fairphone after water damage, a nasty fall, or a lightning strike, by replacing your motherboard.
If it’s still possible to do so, save your data to an SD card before disassembling your phone.
Выберете то, что вам нужно
With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
Use a fingernail in this indentation to push the battery toward the top of the phone
Pull the battery out away from the phone.
Use your finger to slide the SIM card straight down out of its tray.
Remove the SIM card from your Fairphone.
If you have a microSD card, use your finger to slide it straight out of its slot.
Remove the microSD card from your phone.
Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
Use an opening pick to carefully pry the midframe away from the display assembly.
Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
Use tweezers to remove the volume rocker and power buttons from the display assembly.
Use tweezers to remove the adhesive foam tape from the top of the digitizer cable ZIF socket.
Use the tip of a spudger to flip open the tab on the digitizer ZIF connector.
Use tweezers to pull the digitizer cable away from its socket on the motherboard.
Remove the three 2.5 mm Phillips #000 screws securing the motherboard to the display assembly.
Gently lift the top end of the motherboard up to expose the display data cable.
Use the tip of a spudger to disconnect the display data cable from the back of the motherboard.
Use the flat end of a spudger to disconnect the rear-facing camera cable connector from its socket on the motherboard.
Remove the rear facing camera from the motherboard.
8 участников успешно повторили данное руководство.
Один комментарий
This is a wonderful and detailed guide - thank you. However, I followed the instructions precisely and whilst the phone now switches on perfectly, the touchscreen does not work. Thoughts on how ifixthat welcome!!
