Введение
Use this guide to replace the Wi-Fi antenna daughterboard in your Fairphone.
Запчасти
Никакие детали не требуются.
  1. There is a small indentation in the side of the phone near the bottom of the back cover. With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone. With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
    • There is a small indentation in the side of the phone near the bottom of the back cover.
    • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
  2. Slide the back cover down and remove it from the phone. Slide the back cover down and remove it from the phone. Slide the back cover down and remove it from the phone.
    • Slide the back cover down and remove it from the phone.
  3. There is a small indentation in the back of the phone just below the battery. Use a fingernail in this indentation to push the battery toward the top of the phone Pull the battery out away from the phone.
    • There is a small indentation in the back of the phone just below the battery.
    • Use a fingernail in this indentation to push the battery toward the top of the phone
    • Pull the battery out away from the phone.
  4. Remove the battery from your Fairphone.
    • Remove the battery from your Fairphone.
  5. Use your finger to slide the SIM card straight down out of its tray. Remove the SIM card from your Fairphone. Repeat this procedure if you have a second SIM card.
    • Use your finger to slide the SIM card straight down out of its tray.
    • Remove the SIM card from your Fairphone.
    • Repeat this procedure if you have a second SIM card.
    • Be sure to remove all SIM cards before servicing your phone.
  6. If you have a microSD card, use your finger to slide it straight out of its slot. Remove the microSD card from your phone.
    • If you have a microSD card, use your finger to slide it straight out of its slot.
    • Remove the microSD card from your phone.
  7. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  8. Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
    • Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
  9. The midframe is secured to the display assembly by several small plastic clips. Use an opening pick to carefully pry the midframe away from the display assembly. Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
    • The midframe is secured to the display assembly by several small plastic clips.
    • Use an opening pick to carefully pry the midframe away from the display assembly.
    • Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
  10. Carefully round the corner, separating the midframe from the display assembly. Carefully round the corner, separating the midframe from the display assembly.
    • Carefully round the corner, separating the midframe from the display assembly.
  11. After rounding the next corner, the midframe should be free along the bottom and the sides.
    • After rounding the next corner, the midframe should be free along the bottom and the sides.
  12. Run the opening pick and pry along the top seam. To avoid bending or damaging the opening picks, do not pry near to the power switch, USB port, or headphone jack. To avoid bending or damaging the opening picks, do not pry near to the power switch, USB port, or headphone jack.
    • Run the opening pick and pry along the top seam.
    • To avoid bending or damaging the opening picks, do not pry near to the power switch, USB port, or headphone jack.
  13. Separate any remaining clips and remove the midframe from the phone.
    • Separate any remaining clips and remove the midframe from the phone.
  14. Use the flat end of a spudger to disconnect the antenna cable connector.
    • Use the flat end of a spudger to disconnect the antenna cable connector.
    • Be careful to pry on the connector, not the socket.
  15. Use the tip of a spudger to flip open the tab on the daughterboard data cable ZIF connector. Use tweezers to pull the daughterboard data cable away from its socket. Use tweezers to pull the daughterboard data cable away from its socket.
    • Use the tip of a spudger to flip open the tab on the daughterboard data cable ZIF connector.
    • Use tweezers to pull the daughterboard data cable away from its socket.
  16. Remove the following screws securing the Wi-Fi daughterboard to the display assembly:
    • Remove the following screws securing the Wi-Fi daughterboard to the display assembly:
      • Two 2.5 mm Phillips #000 screws
      • One 1.6 mm Phillips #000 screw
  17. The Wi-Fi antenna daughterboard is held to the front assembly by mild adhesive. Use tweezers to gently pry the board up and remove it from the phone.
    • The Wi-Fi antenna daughterboard is held to the front assembly by mild adhesive.
    • Use tweezers to gently pry the board up and remove it from the phone.
Заключение
9 участников успешно повторили данное руководство.
Andrew Optimus Goldberg
Участник с: 17.10.2009
402 400 Репутация
Автор 412 руководств
Команда
iFixit Member of iFixit
Community
109 членов
Автор 7 714 руководств
Один комментарий
I would suggest to rename the guide to "Fairphone Wi-Fi Antenna and Microphone Daughterboard Replacement", because it is also what you need to do to replace a broken fairphone microphone.
Torsten - Ответить
Просмотр статистики:
За 24 часа: 6
За 7 дней: 77
За 30 дней: 308
За всё время: 9,122
