Введение
Use this guide to replace the speaker module in your Fairphone 3.
Выберете то, что вам нужно
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
Pry the back cover up to start separating its plastic clips.
Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
Lift the back cover to release the rest of the plastic clips and remove it.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
Lever the battery up until you can get a good grip.
Insert an opening pick between the midframe and the display module on the right edge of the phone.
Slide the opening pick down to the bottom right corner to pry open the plastic clamps of the display module.
Slide the opening pick around the bottom right corner and use it to disengage the plastic clamps at the bottom of the display module.
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
6 участников успешно повторили данное руководство.
2 Комментариев
Super einfach, danke für die tollen Bilder.
Ich hab dies nur gemacht um das Phone mal wieder von Staub zu befreien, vor allem bei den Lautsprecheröffnungen hat sich einiges angesammelt.
Ein “Frühjahrsputz” ist bei diesem Gerät tatsächlich eine Option :)
