Введение
Use this guide to repair the clear indicator light. This guide will help you through replacing the light bulb.
Выберете то, что вам нужно
Turn toaster upside down so screws on bottom side are facing toward the ceiling and the door is facing towards you.
Remove the panel on the left hand side. The indicator light is located in the red tube that has wires covered by black tubing coming out.
Еще один человек закончил это руководство.
