Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This fast fix is to fix the buttons on a 2006 Honda Cr-V key fob. It is a very simple and easy fix. You will only need one tool and the replacement part.
Инструменты
Запчасти
  1. You will need to take the key off the ring.
    • You will need to take the key off the ring.
  2. The second step is to take out the little screw on the back side of the key.
    • The second step is to take out the little screw on the back side of the key.
  3. Unclip the back part of your key.
    • Unclip the back part of your key.
    • This part is super fragile.
  4. You will push the buttons from the front side to have the middle piece fall out.
    • You will push the buttons from the front side to have the middle piece fall out.
  5. Then you will unclip the middle part. There is one clip on each side of this piece. They are super fragile and can break easily. Then you will unclip the middle part. There is one clip on each side of this piece. They are super fragile and can break easily.
    • Then you will unclip the middle part. There is one clip on each side of this piece. They are super fragile and can break easily.
  6. Then push the buttons from the front side to push out a rubber insert. Then push the buttons from the front side to push out a rubber insert.
    • Then push the buttons from the front side to push out a rubber insert.
  7. Then peel out the mother chip and replace your rubber insert.
    • Then peel out the mother chip and replace your rubber insert.
Заключение
Spencer Greer
Участник с: 11.04.2019
145 Репутация
1 руководство автора
Команда
Eastern Washington University, Team S25-G5, Crane Spring 2019 Участник Eastern Washington University, Team S25-G5, Crane Spring 2019
EWU-CRANE-S19S25G5
4 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 14
За всё время: 327
