Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This fast fix is to fix the buttons on a 2006 Honda Cr-V key fob. It is a very simple and easy fix. You will only need one tool and the replacement part.
Выберете то, что вам нужно
You will push the buttons from the front side to have the middle piece fall out.
Then you will unclip the middle part. There is one clip on each side of this piece. They are super fragile and can break easily.
2 участников успешно повторили данное руководство.
2 Комментариев
How do you remove the key from broken fob and put in new fob so you don’t have to incur the cost of cutting new key?
Just open the fob, like in this tutorial. The key is just a piece of metal.
Then place the key in a new fob (or replace only the fob plastic case for a cheaper solution).
Brendan -
