Введение
Use this guide to replace a faulty impeller in the circulation pump (model P-150) of your Fluval Spec V Aquarium.
The impeller is a crucial component that drives water circulation within your aquarium setup. Over time or due to various factors, the impeller can become damaged, leading to reduced circulation or complete halt, both of which can have negative impacts on the wellbeing of your aquatic life. This guide walks you through the steps of replacing the impeller to restore optimum water circulation.
While this repair does not pose significant hazards, caution is required to ensure the safety of your aquarium's inhabitants, particularly if you have delicate species like Neocaridina shrimps. This guide includes necessary precautions to prevent them from getting stuck inside the filtration compartment during the repair.
You will need a pry tool like a smell flathead screwdriver for this repair, and a pair of needle nose pliers may come in handy. Both are common tools and don't require any special skills to use.
For additional information on maintaining your Fluval Spec V Aquarium, you may refer to the official manual.
Remember to disconnect the aquarium from power before starting the repair to ensure safety. Happy repairing!"
Выберете то, что вам нужно
Remove Light: Carefully lift light from its mount, ensuring not to pull on any wires.
Remove Lid Securely grasp edge of the aquarium lid and lift up to remove.
Insert Pry Tool: Take a small, flat-head screwdriver or pry tool and carefully insert it between the nozzle and the filter tube.
Pry Off Nozzle: Carefully apply some leverage to pry nozzle away from the filter tube. It should gradually detach.
Pull Out Filter Tube: Grasp the filter tube firmly and pull it out from the divider.
Cover Outlet (Optional): Carefully insert a suitable filter medium into the outlet.
Pull Up on Output Tube: Firmly grasp the output tube and pull straight up. The pump should follow along, detaching from the bottom of the aquarium.
Drain Excess Water: Hold pump over the tank for a moment to allow any excess water to drain out of the pump.
Insert Pry Tool: Take your small pry tool and carefully insert it anywhere under the edge of the pump cover.
Pry Off Cover: Gently pry it off by twisting the tool.
Insert Pry Tool: Carefully insert your pry tool anywhere under the edge of this cover.
Pry Off Cover: Gently pry it off.
Grasp Impeller: Get a firm but gentle grip on the impeller.
Pull Out Impeller: Slowly and carefully pull it straight out.
Install New Impeller: Take your new impeller and carefully align the slot with the pin in the impeller housing. Gently slide the new impeller on to the pin, ensuring that it's oriented correctly.
2 человек успешно провели ремонт по этому руководству.
