Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
With this step by step repair guide, you will be able to replace a fog light for a 2005 Jeep Liberty.
Запчасти
  1. Open the hood to access the radiator grill tabs.
    • Open the hood to access the radiator grill tabs.
    • Pull up on the first tab and repeat for the remaining four tabs.
  2. Tilt the radiator grill cover forward and lift up and out to remove.
    • Tilt the radiator grill cover forward and lift up and out to remove.
  3. Using an allen wrench,  turn the tension screw counter-clockwise to loosen the light housing.
    • Using an allen wrench, turn the tension screw counter-clockwise to loosen the light housing.
  4. Lift up on the tension screw to release the light housing.
    • Lift up on the tension screw to release the light housing.
  5. Using a flat-head screwdriver, pull the tab outward to remove the light housing.
    • Using a flat-head screwdriver, pull the tab outward to remove the light housing.
    • Repeat the procedure for the right side of the light housing.
  6. Pull the light housing toward you.
    • Pull the light housing toward you.
  7. Remove the wiring harness from the light socket by lifting up on the tab with a flat-head screwdriver.
    • Remove the wiring harness from the light socket by lifting up on the tab with a flat-head screwdriver.
  8. Remove the light socket from the light housing by turning counter-clockwise.
    • Remove the light socket from the light housing by turning counter-clockwise.
  9. Remove the light socket from the light housing and replace.
    • Remove the light socket from the light housing and replace.
    • The light socket part number is 9145 and can be purchased at any auto parts store.
    • Install the new light socket back into the light housing by turning clockwise.
    • Plug the wiring harness back in the light socket.
Заключение
Test the replacement light socket by turning the lights on. If working, reinstall the light housing and radiator grill cover.
Еще один человек закончил это руководство.
CHARLES CATLEDGE
Участник с: 17.09.2017
161 Репутация
1 руководство автора
Команда
Pasco Hernando, Team S4-G55, Prince Winter 2017 Участник Pasco Hernando, Team S4-G55, Prince Winter 2017
PHSC-PRINCE-W17S4G55
1 член
Автор 1 руководств
Комментариев: 2
Thank you for your information, if you are looking for a place that sells the best and most trusted car fog lamps. Check this out!
vievie aryanti - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 14
За последние 7 дней: 57
За последние 30 дней: 318
За всё время: 3,598
