Выберете то, что вам нужно
Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
Once the top is separated, use your hand to remove the back panel from the unit.
There will be two black wires connecting the top mounting bracket to the reverb box at the bottom of the unit. Label the wires to prevent crossing upon re-installation, then unplug the wires from the reverb box.
Label and unplug the two red wires connecting the mounting bracket to the speaker by pulling them off the nodes.
Use a Phillips #1 screwdriver to unscrew the four 36.4 mm screws holding the mounting bracket to the top of the amp.
Pull the mounting bracket free from the frame. It may be wedged in very snug, in which case, use a plastic opening tool/spudger to pry it loose from the front.
Mark, make note of, or remember the arrangement of the wires.
Remove the four female disconnected terminals from the switch terminals.
Using the flat end of a spudger, push in one of the wedged locking clips.
Partially tilt the switch box so that clip is held down.
Repeat for the other side of the switch
Be sure that both locking clips are pressed through the opening. This may take a few tries.
Gently remove the switch.
Once the old power switch is removed, install the new one by following the guide in reverse.
Еще один человек закончил это руководство.
