Введение
If the speaker is dead or blown, install a new one.
Выберете то, что вам нужно
Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
Once the top is separated, use your hand to remove the back panel from the unit.
Using tape or a post-it, label the input and output wires on the reverb. Remove these wires from the box.
Use a Philips #1 screwdriver to remove the four 21.9 mm Phillips screws from the perimeter of the speaker.
To install the new speaker, follow the instructions given in reverse.
Еще один человек закончил это руководство.
