Firmware update or recovery - PC (All models)
Выберете то, что вам нужно
  1. Firmware update or recovery - PC (All models), Plug the controller in: шаг 1, изображение 1 из 1
    • Connect the controller using a USB-C OR MicroUSB cable. Plug the controller into a USB port on your PC.
    • Bluetooth firmware updates are not supported.
  2. Firmware update or recovery - PC (All models), Download the Xbox Accessories app.: шаг 2, изображение 1 из 2 Firmware update or recovery - PC (All models), Download the Xbox Accessories app.: шаг 2, изображение 2 из 2
    • Download the Xbox Accessories app from Microsoft Store using this link.
    • After it has finished downloading, you can launch it either straight off the app's page or from your Start Menu.
  3. Firmware update or recovery - PC (All models), Prepare the app for the firmware update: шаг 3, изображение 1 из 2 Firmware update or recovery - PC (All models), Prepare the app for the firmware update: шаг 3, изображение 2 из 2
    • After you launch the app and it finishes loading, the controller should show up like on the first photo.
    • Click on the three dots under the Configure button.
    • If the button over the Buzz/Vibrate this controller says No update available, your controller is already up to date and the guide ends here.
  4. Firmware update or recovery - PC (All models), Update the firmware: шаг 4, изображение 1 из 2 Firmware update or recovery - PC (All models), Update the firmware: шаг 4, изображение 2 из 2
    • Press the Continue button and wait for the process to finish.
    • In most cases, the firmware can be recovered, but be careful not to disconnect the controller during the update. Any loss of connection, be it disconnecting or PC power loss may damage the controller beyond repair.
    • After the update, press Close. Your controller is now up to date and should be fully usable with your PC, Xbox One or Series S/X consoles.
Финишная прямая
6 человек успешно провели ремонт по этому руководству.
SojerManLan
Участник с: 07/07/21
253 Репутация
1 руководство автора
1 Комментарий к руководству
Use this video if you need to undo anything.
Revert Firmware
go away - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 39
За последние 30 дней: 126
За всё время: 6,012
