Введение
If the amplifier is not turning on when you press the power switch, you may want to replace the batteries. Each 9-volt battery provides power to the amplifier. It is crucial to have good batteries to enhance functionality of your amplifier.
Выберете то, что вам нужно
Press the bottom tab and lift the lid that is marked "9V Battery"
Open the lids of both battery cartridges, use a Spudger to lift the 9-volt battery out.
Disconnect the attached 9-volt battery from the positive and negative terminal connections to prepare for replacement.
Insert a new, fully-charged 9-volt battery to the terminal connections.
Link the positive terminal (+) of the 9-volt battery to the positive connection.
Link the negative terminal (-) of the 9-volt battery to the negative connection.
Repeat the process for the 2nd 9-volt battery in the neighboring cartridge.
Insert the 9-volt battery into the cartridge.
Press firmly to slide the battery into the cartridge, and close the tab to ensure the battery is secured.
Close the tab after the battery is secured, until the tab "clicks" into place.
Make sure connections are secure and insert 9-volt batteries into the battery cartridges.
Close the tabs until you hear a click.
Now, try turning on the power switch. Get ready to rock & roll!
