First Act MA2039 Battery Replacement
Выберете то, что вам нужно
  1. First Act MA2039 Battery Replacement, Battery: шаг 1, изображение 1 из 3 First Act MA2039 Battery Replacement, Battery: шаг 1, изображение 2 из 3 First Act MA2039 Battery Replacement, Battery: шаг 1, изображение 3 из 3
    • Press the bottom tab and lift the lid that is marked "9V Battery"
    • Open the lids of both battery cartridges, use a Spudger to lift the 9-volt battery out.
    • Disconnect the attached 9-volt battery from the positive and negative terminal connections to prepare for replacement.
  2. First Act MA2039 Battery Replacement: шаг 2, изображение 1 из 3 First Act MA2039 Battery Replacement: шаг 2, изображение 2 из 3 First Act MA2039 Battery Replacement: шаг 2, изображение 3 из 3
    • Insert a new, fully-charged 9-volt battery to the terminal connections.
    • Link the positive terminal (+) of the 9-volt battery to the positive connection.
    • Link the negative terminal (-) of the 9-volt battery to the negative connection.
    • Repeat the process for the 2nd 9-volt battery in the neighboring cartridge.
  3. First Act MA2039 Battery Replacement: шаг 3, изображение 1 из 2 First Act MA2039 Battery Replacement: шаг 3, изображение 2 из 2
    • Insert the 9-volt battery into the cartridge.
    • Press firmly to slide the battery into the cartridge, and close the tab to ensure the battery is secured.
    • Close the tab after the battery is secured, until the tab "clicks" into place.
  4. First Act MA2039 Battery Replacement: шаг 4, изображение 1 из 2 First Act MA2039 Battery Replacement: шаг 4, изображение 2 из 2
    • Make sure connections are secure and insert 9-volt batteries into the battery cartridges.
    • Close the tabs until you hear a click.
    • Now, try turning on the power switch. Get ready to rock & roll!
Заключение
Luke VanBuskirk
Участник с: 04/05/18
279 Репутация
Автор 2 руководств
Команда
Linn Benton Community College, Team S1-G5, Johnson Spring 2018 Участник Linn Benton Community College, Team S1-G5, Johnson Spring 2018
LBCC-JOHNSON-S18S1G5
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 14
За всё время: 692
