Введение
Is your Fitbit Surge battery not charging no matter what you do? Read this guide to learn how to replace the battery, but keep in mind that you will need to cut the wristband in order to complete this repair and the band cannot be reattached.
Выберете то, что вам нужно
Unscrew all four black 3 mm Phillips screws on the underside of the watch using a T5 screwdriver.
Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
Note: Part of the band is hard plastic.
Caution: The band cannot be reattached once it is cut.
Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
Use a PH000 screw head to undo the newly revealed silver 4 mm Phillips screws that were hidden beneath the glue.
Using a metal spudger, push down on the plastic gray square clamps on the underside of the device to dislodge the whole silver backing.
Note: the buttons will also come off.
Use a pick or small flathead to remove the 4 metal clamps holding device together.
Use a thin tool to pry the the device apart by lodging it between the clock face and back side of the device.
To reassemble your device, follow these instructions in reverse order. Keep in mind that the band will need to be cut for this repair and it cannot be reattached.
11 участников успешно повторили данное руководство.
10 Комментариев
I'm about to embark on replacing the battery for my fitbit surge. After having it for over 2 years it requires a charge about twice a day which get annoying.
Does removing/replacing the battery require the moderate soldering skill?
Looks like it must.
The last photo I think shows the tool prying the force feedback motor, the battery is the white plastic covered slim brick on the top right.
You do not need to cut bands off
The replacement battery for the Fitbit Surge can be found here:
It also includes all of the tools (except soldering iron) needed for the repair.
