Введение
Use this guide to adjust ski bindings to fit a new skier.
The ski binding is the device that connects your ski boot to the ski. When a skier gets a new pair of ski boots, it’s unnecessary to purchase a new pair of skis or pay someone to adjust the bindings. Instead, you can use this guide to learn how to adjust the bindings yourself.
This guide shows you how to adjust the location of the bindings as well as the DIN setting. Your DIN setting is a function of your height, weight, and a few other personalized parameters. Before using this guide, calculate your DIN setting here.
Инструменты
Запчасти
Детали не указаны.
Locate the boot size (in millimeters) on the bottom of the boot.
Place your ski on a flat surface with the ski bindings facing up.
Locate the lever on the side of the heel piece of the binding.
Lift and hold the lever in the upright position.
With the lever raised, slide the heel piece until the markers point to the correct range of the boot size.
Locate the lever on the toe piece of the binding.
With the lever raised, slide the toe piece until the markers point to the correct boot size range.
Insert the toe of the boot into the toe piece of the binding.
Push down on the boot and up on the lever on the heel piece until the boot clips into the binding.
Insert the screwdriver in the front of the toe piece.
Loosen the screw until the toe bar moves backwards.
Insert a piece of paper between the bottom of the boot and the toe bar.
Tighten the screw at the front of the toe piece until there is resistance when pulling the paper out.
Adjust the DIN setting on the toe piece to your personalized setting by tightening or loosening the screw on the side of the bindings.
Look at the window on the top of the toe piece to see the current DIN setting.
Repeat step 9 but on the heel piece.
Adjust the DIN setting on the heel piece by tightening or loosening the screw on the back.
Look at the window on the top of the heel piece to see the current DIN setting.
Repeat this guide on the other ski and you’re ready to go!
