Введение
Flat-screen TVs are often secured to the wall using wall mounts. If your wall mount (Mounting Dream MD2462) is coming out of the wall, you can use this guide to repair it. Loose screws can potentially cause the TV to fall out of the wall, creating a safety hazard. Be sure to unplug the cables in your TV before beginning this repair.
It is also essential to note that this product contains small items which may be choking hazards for children. Before beginning this guide, make sure that all the parts are in good condition. The product also includes some extra hardware components, which might not be needed.
Выберете то, что вам нужно
Remove the two M4x5mm bolts on the back of the TV plate using a Phillips #00 screwdriver.
Locate the wooden studs on the wall using a stud finder or knock on the wall to see if the stud is behind the wall.
Use a pencil to mark three holes on the wall.
Use a 3/8-inch drill bit to drill three holes at the marked positions.
Secure the wall mount into the wooden studs using new screws or bolts.
Make sure the TV is secure and well-centered on the wall mount using a spirit level gauge to confirm the inclination.
Еще один человек закончил это руководство.
