Выберете то, что вам нужно
Flip device upside down and remove the 4 foam pads at each corner.
Unscrew the 5 screws in the base circuit board.
Use the tweezers to slightly lift the circuit board, allowing the cylindrical alarm piece to slide out.
If they are not attached, you may re-solder it together. If they are attached, that means it is a faulty alarm and should replace it.
3 участников успешно повторили данное руководство.
