Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
I am going to create a guide on how to fix a small animal ladder. This ladder is about 12.5 inches in length and 4.5 inches in width. This ladder consists of small cylinders resembling stairs that are attached to each other with enough stability to hold a small animal. The issue with this item is that the rope holding these small cylinders making the ladder continue to fall off and detach from the rest of the pieces, leaving wood hanging in two separate strands no longer resembling a ladder. There is rope holding these cylinders creating the ladder together and it teared over time and use. To avoid going to the store and having to buy a new one I want to just fix the issue where it lies. The idea is to get a new rope from a repair shop such as Lowes or Home Depot and remove the old rope from the ladder and replacing it with the new one.
Выберете то, что вам нужно
Take your ladder out of the pet’s cage and lay it out to clearly assess the damage.
Gather your supplies for the fix (ie: new rope, scissors, ruler, sewing kit, clips). These items will be used to fix the small ladder.
Cut the old rope in the ladder with scissors and pull it out of the cylindrical wood pieces.
Begin pushing rope through the individual holes in the wood pieces (use a sewing kit if necessary).
Once all the rope has connected the wood into a ladder, tie knots at each end to keep the pieces together.
