Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
If the casing of your device becomes damaged and needs replaced we have provided you helpful guides to do so. This should be an easy fix and with just a few tools the casing will be removed!
Запчасти
Детали не указаны.
  1. With the plastic opening tool, remove labels from the Flip Mino HD. 2 small black screws should appear. With the Phillips Screwdriver 000, unscrew the 2 screws and set aside in a safe place.
    • With the plastic opening tool, remove labels from the Flip Mino HD. 2 small black screws should appear.
    • With the Phillips Screwdriver 000, unscrew the 2 screws and set aside in a safe place.
  2. With the plastic opening tool, gently pry the front casing away from the device by carefully running the tool around each edge and lifting. Do not pull to remove the casing until all sides are loose. You may break or crack the case.
    • With the plastic opening tool, gently pry the front casing away from the device by carefully running the tool around each edge and lifting.
    • Do not pull to remove the casing until all sides are loose. You may break or crack the case.
    • Once case is loose, flip up and over the device. Note that casing is still connected to the device.
    • Using tweezers, pull connecting strip to disconnect it from its socket on the logic board.
Заключение
Еще один человек закончил это руководство.
Abigail Buckenberger
Участник с: 06.01.2016
678 Репутация
Автор 5 руководств
Команда
Eastern Washington University, Team 2-1, Andersen Winter 2016 Участник Eastern Washington University, Team 2-1, Andersen Winter 2016
EWU-ANDERSEN-W16S2G1
4 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 473
